  • hleboeuf Friend
    #186646
    I’m using RSForm Pro on the site and when using a multi tapped form all Tabs display beneath eachother.
    The guys from RSJoomla say this is a template problem ..
    This is the URL on our test-environment.
    http://www.dewildeeend.be/_d3mo/index.php/lid-worden
    I hope one of the guys here can help me because if not this is going to be a ping-pong between Joomlart and RSJoomla …
    Kid Regards
    phong nam Friend
    #489622
    Hi hleboeuf,
    Can you send me link download RSForm Pro or attach RSForm Pro package are you using on your site? I will check it and help to get some solution for you.
    Regards,
    Leo
    hleboeuf Friend
    #490009
    Leo, sorry, that deo site was taken offline.
    But meanwhile the problem was solved.
    I was migrating van an older version of joomla to the demo site, and backup/restored all my forms and subscriptions.
    But is is better to regenerate the layout in the newer 30 version.
    Once i did that the forl was working fine.
This topic contains 3 replies, has 2 voices, and was last updated by  hleboeuf 11 years, 7 months ago.
