  • danae5d Friend
    #129876
    Hi, I have a big problem with the component RSGallery 2, first I installed Ja Helio Quickstart, and everithing was Ok, then I installed the RS Gallery component witn the following error:
    Fatal error: Class ‘JSite’ not found in /home/lalolaco/public_html/templates/ja_helio/ja_menus/Base.class.php on line 142
    Then I installed JA Avian Quickstart with the RS Gallery component and the gallery worked fine, but when I installed JA Helio template, the same error, I think that there are incompatibilities, please help me I want JA Helio with RS Gallery, I tried 5 times!
    #254864
    Can you send your URL ? If okie, plz send me an account via PM
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 16 years, 5 months ago.
