January 20, 2009 at 9:38 pm #137301
I have a few problems with the template that I’d love some help in resolving.
The URL of the site is http://communityaction.mkatek.net
First problem is that I have Slideshow module installed, enabled, and in the proper position, yet, as you can see, it still doesn’t show up. The screenshot with the configuration of the module is attached.
The second problem is that the search button at the top of the page is gone. Not sure when or why, but it is no longer there and I am not sure how to get it back. Any help with this would be much appreciated.
Thank you!
jwellman Friendjwellman
- April 2008
- 59 times in 21 posts
January 20, 2009 at 11:50 pm #287366You’ve probably already done this, but you can double check. I helped someone with the same problem in the past and by looking at your screenshot I’m not able to see your complete image path. Make sure at the end of the path you have a backslash at the end. See Example:
images/stories/slideshow_winter/
- April 2008
January 21, 2009 at 12:05 am #287370Thanks for the reply.
On the first issue, yes, there is a backslash at the end of the path. So it is still outstanding.
On the second issue .. all I can say is .. duh. Thanks!
January 21, 2009 at 1:40 am #287375an update:
something is wrong here with the documentation of the template, or something
1. If I assign the module to topsl1 – nothing is visible
2. If I assign the module to topsl – see what happens at http://communityaction.mkatek.netJanuary 21, 2009 at 4:27 am #287385Well, I am pretty sure that the corrent module position is topsl, not topsl1. But it still looks bad – so any help would be much appreciated.
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by kniaz 15 years, 11 months ago.
Problems with Search and topsl1
