  • structuralia Friend
    #1022078
    I’m creting a new home page, following the docs from https://www.joomlart.com/documentation/joomla-templates/ja-builder (I don’t know if other docs are available).
    The sections are correctly created (5 sections). After, I used the "Pages"->"Import to current page"->"From Library" option menu, and then, I selected the "home 1.16" template.
    When the template is successfully imported, all the blocks are created but in the "content" section.
    When I created a new block, I can use the "Move to upper section" and "Move to lower section" buttons, but in the blocks imported from library, the buttons don’t appear.
    Could you send me the URL of page where I can see the issue?
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 7 years, 9 months ago.
