shemeam Friend
shemeam
- 16 times in 4 posts
October 31, 2017 at 11:27 pm #1071449HI there
I have a problem after upgrade, I updated the template, T3 and Joomla to version 3.8.1. It had been quite a while since I upgraded the website so it progressed a few versions.
I have a custom module called ‘What is Neighbourhood Planning?’ which is a small amount of text positioned in the sidebar on the home page (currently disabled).
The first image i have attached shows what happens when I enable the custom module.
The second image (wwnp.jpg) shows how it used to look.Please can you help me to resolve this so this custom module fits in the sidebar1 and not across the page.
Many thanks Alison
- This topic was modified 7 years ago by shemeam. Reason: adding an image
Pankaj Sharma Moderator
Viewing 2 posts - 1 through 2 (of 2 total)This topic contains 1 reply, has 2 voices, and was last updated by Pankaj Sharma 7 years ago.
