  • tricky177 Friend
    #137252
    Can someone please direct me to more information about the the above module as I can’t seem to find more details about it on the forums?
    I expected it to work ‘out of the box’ but when I use it with Edenite (developing on my local machine) but when I assign it to user1, user2 and user5, it does not work correctly.
    The image and title shows but the moving bar that should slide up when the mouse is moved over it doesn’t work.
    sunrise Friend
    #287102
    Hi, tricky 177
    Sound like the same problem I had some time back. Here is a link to the thread. If you have problems after you read this, let me know and I’ll try to help.
    http://www.joomlart.com/forums/topic/mod_ja_slwi-in-fagus/
    tricky177 Friend
    #287108
    Hi sunrise
    Thank you for taking time to reply to my post. I’ll take up the advice in the thread you posted.
    I’ve only just signed up to Joomlart and have run into a few problems like this. I browsed the site but can’t seem to find an area that is concerned with using modules/ extensions with different templates (other than in the forums).
    Am I missing something or are there no tutorials that cover simple problems like the one above?
    thanks again
    tricky177 Friend
    #287113
    Nice work sunrise, I added the code to my template’s css and it now works with IE7 but unfortunately, not with FF. Don’t suppose you or anyone else can point me in the right direction?
    Edit** Whoops, forgot to clear cache in FF- works now…
    sunrise Friend
    #287169
    <em>@tricky177 106895 wrote:</em><blockquote>Hi sunrise
    thanks again</blockquote>
    I’m glad you got it working. It can be frustrating to not get these simple things worked out. I don’t think there are tutorials for all the various situations that arise, although it would be a good idea. But JoomlArt has a great and active forum and it is usually quite easy to get the answers you need.
This topic contains 5 replies, has 2 voices, and was last updated by  sunrise 15 years, 11 months ago.
