  • inetworking Friend
    #166174
    :confused:
    Hello
    I mounted the module “Spotlight Module Content with Image” as the guide puts but I have 2 problems.
    – That is misconfigured, that create 2 lines instead of lines, we can arrange this as
    http://inetworkingdemo.com/jaquartz/
    – As poduedo resize the area where this text, color, to make it smaller.
    thanks
    1. servicios
    2. servicios2
    himangi Friend
    #400647
    Since the spotlight type is being used, it divides the whole area into number of images you have specified to display in the module. I would suggest you to increase image widths to be 225px max and do the following changes in template.css so that the images will fit in the available area on a single line.
    On line 1342
    <blockquote>div.ja-catslwi {
    width: 226px;
    float: left;
    } </blockquote>Change width to 225px
    On line 1351
    <blockquote>.ja-catslwi-center {
    margin: 0 10px 0 5px;
    }</blockquote> Change margin to 0 11px 0 5px
    On line 1347
    <blockquote> .ja-catslwi-first {
    margin-right: 10px;
    }</blockquote> Change Margin-right to 11px
    inetworking Friend
    #400699
    Thanks for the solution has worked for me was what I needed. Thank you.
    Now to finish at all, I wanted to know how to move the images left or a few pixels to reduce the distances between pictures, so the original photo on the left and right the end of the line are not touching the box that surrounds them.
    :confused:
    1. margenes
    himangi Friend
    #400705
    Find the previous styling you have changed in template.css and make further changes as below.
    .ja-catslwi-first {
    margin-right: 9px;
    margin-left: 10px;
    margin: 0 9px 0 0px;
    .ja-catslwi-last {
    margin-right: 10px;
    inetworking Friend
    #400829
    Thanks, worked perfertamente, but now it’s the opposite side, the right one pixel to the right and will be perfect:-*
    1. margenes2
    himangi Friend
    #400898
    You have written margin-left instead of margin-right in
    .ja-catslwi-last {
    margin-right: 10px;
    inetworking Friend
    #401179
    Everything is ok thank you very much:laugh:
This topic contains 7 replies, has 2 voices, and was last updated by  inetworking 13 years, 5 months ago.
