  • jujujiju Friend
    #997413
    Hello! I’ve updated the template to the latest version, and after updating, the Copyright module shows other information. I would like to remove the information from the Joomla kernel and also modify the section that says "Designed By".
    Thank you very much
    Pankaj Sharma Moderator
    #997478
    Open /templates/ja_directory/html/mod_footer/default.php file and you can change or remove the copyright info .
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 11 months ago.
