  • iventit Friend
    #193615
    I work locally and, if necessary, I will work online (I’m developing). But I have problems with the template. I describe you below:
    1. Problem with the module search : see attachments (image10 image02 and)
    As shown in the image01 when the desired module is activated, it has the number “0” that appears it systematically. When quenched, he leaves. What is it due?
    2. Displaying items.
    I fail to see the related items menu. A page blache apparraĆ®t and that’s all. Illustration image03.
    Please help me. Thank you.
    1. image01
    2. image02
    3. image03
    Please find answers to your questions below:
    1. Since your site is still in localhost, please tell me steps to reproduce this issue, did you install using template quickstart or install template separately? What is your Joomla version? I need those to have a better troubleshooting.
    2. You need to check which layout is assigned to that menu item. That layout may not include component block – which displays content of your site, thus the page looks blank. Hope this tip can help:http://t3-framework.org/documentation/bs3-faqs#layout-config
    iventit Friend
    #518569
    1. I’m installe first quickstart (joomla 3.2) and make update of joomla to 3.2.1
    I also tried to install this template with 3.2.1 but all work fine. Its best if you put your site online and if problem still persists, you can PM me admin and ftp account of your site so that I will have a close look and check for you then.
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 10 years, 10 months ago.
