  • jelgervisser Friend
    #133735
    I have some problems with the read more buttons on my website (see the attached image).
    The text on the button should be “Lees meer” (that’s Dutch for read more). But also the article’s title is placed on the buttons. How do I fix this?
    The problem occurs when whowing a category in category-blog-layout.
    Best regards, jelger
    1. readmore
    shertmann Friend
    #272386
    well that tag comes from the config xml because is a part of html tag you can found it in administrator/components/com_content/config.xml and look for the following lines
    <param name="show_readmore" type="radio" default="1" label="Read More Link" description="TIPIFSETTOSHOWREADMORELINK">
    that must solve your issue
    #272388
    Can you give us your live URL?
    jelgervisser Friend
    #272405
    The url is http://www.jv-webdesign.nl.
    You have to go to “Diensten” and then to “Ondersteuning” (the fourth subitem of the menu).
    Thanks, Jelger
    shertmann Friend
    #272414
    jelger did you check the last post i send?
    jelgervisser Friend
    #272419
    Hello Shertmann,
    Yes, I have seen that post. And I have found the lines you mentioned too. But what do I have to do with these lines?
    And maybe more important, why is this happening?
    Thanks, Jelger
    shertmann Friend
    #272421
    i made a full check of the fagus pack and i found that in the following folder is the modules/mod_newsflash/mod_newsflash.xml near the line 35 you have the following xml tags
    <param name="readmore" type="radio" default="0" label="Read More" description="Show/Hide the Read More button">
    and in the file config.xml in the folder administrator/components/con_content/config.xml you have the following
    near the line 55 you have this code
    but this is from the package not the dutch install so if still you have the problem tell me and i will try to make a dutch install in order to see if i can help you better
    shertmann Friend
    #272422
    well let me ask you something do you insert any data in the aplication yet?
    have you make any modification to the code?
    that will be useful to know beacuse is weird that the label overflow the button area
    jelgervisser Friend
    #272426
    I did not make any modification to the original source code. Not even an update from J1.5.x to 1.5.7, for example. From the very beginning, the template is installed on J1.5.7.
    In my opinion, it’s not so much the label that overflows, but the alias title of the concerning article. And I really don’t understand why the alias title is used.
    Best regards, Jelger
    shertmann Friend
    #272429
    if you are not in a hurry tomorrow i will try to install joomla in my local server to look for the label to see if i found your problem
    jelgervisser Friend
    #272430
    Well, I’m not in a hurry. The site is still online. The only thing is that it’s a weird look…
    I appreciate your help and patience!
    Thanks, Jelger
    shertmann Friend
    #272432
    well part of the fine work is the support and help that we can give between professionals
This topic contains 12 replies, has 3 voices, and was last updated by  shertmann 16 years, 3 months ago.
