Viewing 15 posts - 1 through 15 (of 18 total)
  • vladifor Friend
    #1016019
    Hello!
    1 Problem:
    The problem with the output of the slider after the activation of the filter! Photos of the carousel disappear through one!
    2 Problem:
    I can not configure "Step 3: access "Extensions » Modules" and create JA K2 Filter Module. In the "Filter By Extra Fields" setting panel, enable the "Location" extra field and select the "Depend Range"
    NO FIELD "Depend Range"
    Please help to solve the problems!!!
    Mo0nlight Moderator
    #1016139
    There maybe conflict or misconfiguration on your site, you can share the URL & Admin account.
    Also send screenshot and URL of page where I can see error.
    vladifor Friend
    #1016297
    Mo0nlight Moderator
    #1016478
    Hi.
    this link : http://inmobiliariaplaalicante.es/alquiler/alquiler/chalet-alicante.html is item page and after searching, the view will become list view, all the data in the tag
    <div id="k2Container"...>
    </div>
    Will be replaced.
    If you want the slideshow to remain, you need to move it out of the k2Container div.
    JA K2 Filter does not have show/hide function. You can assign module to a menu item page.
    vladifor Friend
    #1016668
    vladifor Friend
    #1017051
    Mo0nlight Moderator
    #1017057
    You can provide the FTP info so I can investigate it further.
    vladifor Friend
    #1017143
    vladifor Friend
    #1017145
    Luna Garden Moderator
    #1018008
    The output of the slideshow functions from SP Page Builder PRO!
    In this page: http://inmobiliariaplaalicante.es/alquiler/alquiler/chalet-alicante.html
    The Slideshow is built within K2 Article ‘Chalet Alicante’. In K2, all K2 items are put in tag div which has id ‘k2Container’. And JA K2 filter uses this div to detect and create Search Layout. That’s why all Slider Content is replaced after searching. You might use a module to put Slider in.
    There is a conflict between the filter and the slider, it’s clearly visible on the page:
    http://inmobiliariaplaalicante.es/venta/venta/piso-en-alicante.html
    I have entered your link, couldn’t find the error. Post the image capture the conflict here so I can help you to check it.
    vladifor Friend
    #1018303
    I attach two screenshots: On one displays a slider, on the other the slider disappears. Please, by reference this is seen better than in the screenshots!
    1. ScreenShot_20170314194825
    2. ScreenShot_20170314194900
    Mo0nlight Moderator
    #1018526
    I need a closer look for further checking, you can provide the FTP account so I will take a look.
    vladifor Friend
    #1018945
    Mo0nlight Moderator
    #1019265
    Could you send the FTP account also?
    vladifor Friend
    #1019398
    Login to admin panel: http://inmobiliariaplaalicante.es/administrator
    VladiforPla
    iM10al09A@
    The problem is clearly visible on this page: http://inmobiliariaplaalicante.es/venta/venta/piso-en-alicante.html
    1. ScreenShot_20170314194825-1
    2. ScreenShot_20170314194900-1
This topic contains 17 replies, has 3 voices, and was last updated by  Mo0nlight 7 years, 8 months ago.
