  • Ninja Lead Moderator
    #984743
    This is not bug from product, you can see the problem from LESS file on your site, it loads from local path and not real, see the screenshot here: http://prntscr.com/d4yujz
    You can change the config from your hosting and move that source code to LIVE site, you can see it will working as well
    manumoce Friend
    #986243
    After a small period Theme Magic started again. Thank you for you reply.
    manumoce Friend
    #986244
    Thank you! It works.
This topic contains 3 replies, has 2 voices, and was last updated by  manumoce 8 years ago.
The topic ‘Problems with Thememagic in Ja nuevo in local and in remote’ is closed to new replies.
