<em>@brianlz 5426 wrote:</em><blockquote>transmenu appears to be working fine w/Firefox 2. Drops down, retracts, and appears to be linking properly.
What I did notice, however, is your use of vbulletin (mobile>text message), which obviously jumps to another look and menu system. This is probably guided by your structure in vBulletin, although I’ve not used it.
Some “forum” platforms (i.e. SMF) have an option which allows you to inherit your site template and/or CSS. In the case of SMF, however, transmenu has not been troublefree. Currently working on a solution in another forum. Will advise if I get through.</blockquote>
Thanks for the feedback will continue to check on the progress.:D Dragonhart
