brenot Friend
brenot
- March 2011
- 8 times in 3 posts
November 30, 2014 at 12:02 am #203162Hi,
I having issues with uber when i try to install a multilingual website.
i instal at http://192.185.164.72/~cristina/_hinarios/ , and do everything right apparently.
The flags appear, but nothings change
Can somebode helpme ?
thanks
pavit Moderatorpavit
November 30, 2014 at 7:19 am #557021Hi
You should create/duplicate your default template 1 for each language then inside megamenu settings assign to the template the respective language menu
Example : spanish template will have assigned as menu the spanish menu and will be assigned only to the menu items of the spanish menu
repeat the step for every language installed1 user says Thank You to pavit for this useful post
brenot Friendbrenot
- March 2011
November 30, 2014 at 2:15 pm #557050Thanks,
I already created this, one template for each language. But Still not working as expected;
Can you help me?
brenot Friendbrenot
- March 2011
November 30, 2014 at 3:57 pm #557062Thanks A LOT….
Sorry for my mistake….
Can you tell me why the flags are now in other place at the layout?
And can you tall me with I also need to duplicate the template for internal pages? for each language?
brenot Friendbrenot
- March 2011
November 30, 2014 at 4:02 pm #557063I Also experiencing problems with the modules…
I trying to made the home page, just like the sample site, and I Try , by sample, to assign the slideshow module to the portuguese language, and nothing changes.thanks for all
This topic contains 7 replies, has 2 voices, and was last updated by pavit 10 years ago.
