June 10, 2009 at 6:13 pm #141838
Whenever I try to use the jahighslide module I get the following output on the website
{highslide type=”img” height=”200″ width=”300″ event=”click” class=”” captionText=”” positions=”top, left” display=”none” src=”/images/stories/demo/sam-01.jpg, /images/stories/demo/sam-02.jpg, “} {/highslide}
anyone know how to use this module?
Css Magician FriendCss Magician
- October 2014
- 366 times in 263 posts
June 15, 2009 at 9:21 am #307949Hi coppens,
You must install and enable plugin Highslidecarlucci Friendcarlucci
- November 2006
- 17 times in 3 posts
January 17, 2010 at 7:56 pm #329551<em>@duchh 132769 wrote:</em><blockquote>Hi coppens,
You must install and enable plugin Highslide</blockquote>I have had the same problem, I installed the plugin, the directory path of the images is corect.
But there will be no picture, only the title of the module.
The module and the plugin JaHighslide are installed in a template does not Joomlart
What can be?Anonymous ModeratorJA Developer
- 2008 times in 1700 posts
March 3, 2010 at 8:26 am #334609Hi carlucci,
If you use JA Highslide integrated within one specific template, kindly go to respective forum for this template over here: http://www.joomlart.com/forums/forum/joomla-templates-club-member-forums-restricted-to-members-only/ and follow the userguide therein to configure custom JA Highslide accordingly
January 9, 2011 at 10:52 pm #370980i have had a problem with this extention and other JA extentions. when i try to upload the file packets into Joomla! I get this message:
“Error! Could not find an XML setup file in the package.”
I tried to install 3 different extentions from this website and have the same problem. Why is the XML setup file not in the download from this site?Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
January 9, 2011 at 11:15 pm #370984I have tried installing this extension and all is working as expected. Please try downloading it again and if you still have problems please drop me a PM with a super admin logon to your site, a link to your site and a link to this thread.
March 1, 2011 at 1:40 pm #379084It doesn’t work with JA Trona template and I can’t see your linked page, becouse I have just JATC membership… Can you send me that guide? Thanks.
huypl Friendhuypl
- February 2011
- 20 times in 20 posts
March 2, 2011 at 10:34 am #379279Hello Kubec,
Do you also have the same problem with Photo Gallery( mod_jahighslide)? You can try this way. Please go to Photo Gallery and set the position to “right” as default. Make sure you had chose the correct image Path folder. -
This topic contains 8 replies, has 8 voices, and was last updated by huypl 13 years, 9 months ago.
