  • tvhmedia Friend
    #137146
    i use in Joomla 1.5.9
    is the description of the link to appear, the text runs right from the far side out of the template .
    here to see http://redder.un-it.de/index.php/ueber-uns/weblinks
    someone knows the solution?
    Anonymous Moderator
    #286757
    Hi tvhmedia,
    I don’t understand your question.
    Please let me in detail.
    tvhmedia Friend
    #286765
    <em>@JA Developer 106455 wrote:</em><blockquote>Hi tvhmedia,
    Please let me in detail.</blockquote>
    hi JA Developer
    I try. I have the weblink component in Joomla activated and categories and links created. When I click the link, the description appears on the link in a continuous text, but it flows right from the Body and far more about the template. To see in the Image I have appended. Must be something with the Template, because on another page with the same settings, everything is ok.
    mihirc Friend
    #286780
    I think the template css is having a conflict with the weblinks css.
    here is what you will have to do (unless someone suggests something better) –
    1. Load a different css for com_weblinks
    [PHP]<?php if ($option == (“com_weblinks”)) { ?>
    <link rel=”stylesheet” href=”../templates/ja_justicia/css/weblinks.css” type=”text/css” />
    <?php } ?>[/PHP]
    2. Create a new css called weblinks.css. Add the following code to it –
    .spandescription {
    background:#000000 none repeat scroll 0 0 !important;
    color:#CCCCCC !important;
    float:left !important;
    font-weight:bold !important;
    padding:4px 0 !important;
    text-indent:8px !important;
    Regards,
    Mihir Chhatre.
    tvhmedia Friend
    #286783
    Hello Mihir
    at first Thank you for Supporting me.
    I have the new Weblinks.CSS created and laid as templates / ja_justicia / css / weblinks.css . In witch file should i adapt the above code from you?
    <?php } ?>
    mihirc Friend
    #286788
    Add that code in the index.php of the template.
    Location is ../templates/ja_justicia/index.php
    In that find the head tag. add this code there.
    Regards,
    Mihir C.
    tvhmedia Friend
    #286794
    I’ve tried a lot, even the absolute path in the index.php but still the same result. I also cleaned all the cache …
    I was wrong? See this.
    <head>
    <link rel=”stylesheet” href=”http://redder.un-it.de/templates/ja_justicia/css/weblinks.css” type=”text/css” />
    <?php } ?>
    <meta http-equiv=”Content-Style-Type” content=”text/css” />
    or.
    http://redder.un-it.de/templates/ja_justicia/css/weblinks.css[
    mihirc Friend
    #286795
    MY BAD!
    Open the css,
    instead of it being :
    .spandescription {
    IT SHOULD BE:
    span.description {
    tvhmedia Friend
    #286799
    No Way,
    Wat is the right path for…
    href=”../templates/ja_justicia/weblinks.css”
    i try a lot
    href=”/html/redder/templates/ja_justicia/weblinks.css”
    href=”http://redder.un-it.de/templates/ja_justicia/weblinks.css”
    me be this is the Bug
    mihirc Friend
    #286813
    If you trust me, give me the details, i will fix it for you.
    But as i understand, i did check the link that
    and this is correct.
    Regards,
    MIhir C.
    tvhmedia Friend
    #286899
    Thanks for the offer, send me your PM to tomvh@web.de. I do not want too much manipulate the code, and have just given up and disabled the description to the singel Weblink. Is also much less work 😉
    Thanks for your help.
    Thomas
This topic contains 11 replies, has 3 voices, and was last updated by  tvhmedia 15 years, 11 months ago.
