  • Laong Duijndam Friend
    #189805
    When i will put this text “ชุดดรัมเมเยอร์ราคาที่เห็นนั้นเป็นราคาต่อชุด ถ้าสั่ง 1 ชุด แต่ถ้าสั่งมากคิดราคาพิเศษค่ะ”
    In product description in VM the program changed the text There is no problem with English see print screen
    I have installed it in xampp and use the latest quickinstall package from Hawkstore.
    Regards Cees
    1. product-description
    phong nam Friend
    #502675
    Hi Cees,
    You can try to go to Language manager >> Installed – Administrator tab >> Set default to your Thai content language, and clear JAT3 cache then.
    #502777
    Dear Leo,
    The Thai language pack was already installed, the problem is only by the product description, not by the short description.
    But there are more problems with Hawkstore so as Explorer 9 it don’t work there, I have more questions later on the day I will send you a message with the screen dumps of Explorer
    Thank you so much for your help Kind regards Cees
    1. Thai-text-removed-1
    phong nam Friend
    #502787
    Hi Cees,
    Can you send me PM with your website’s credentials again ? I will help you to check this issue.
    #502798
    <em>@Leo Burnetts 385621 wrote:</em><blockquote>Hi Cees,
    Can you send me PM with your website’s credentials again ? I will help you to check this issue.</blockquote>
    Leo that’s impossible I make the site in XAMPP I can send you an Akeeba backup or by post a cd with the info.
    Kind regards Cees
    phong nam Friend
    #502813
    Hi Cees,
    You can install a template demo on our system at http://joomweb.com/, configure the Thai content language. Then send me the admin info, i will check and give you a suitable solution, by that way you can apply on your website.
This topic contains 6 replies, has 2 voices, and was last updated by  phong nam 11 years, 5 months ago.
