August 24, 2007 at 6:52 pm #122317
I’m not sure what I’ve done to make this happen but now clicking on a product opens the product information at the bottom the home page. Wasn’t doing this earlier today. My website is: http://www.gegit.net , this could be computer related but I’ve tried two local computers with the same result. Any help is appreciated.
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
August 24, 2007 at 7:11 pm #228084Do you use the ja-news module on frontpage?
check the settings that it’s set to only show on frontpage(Home)
If that doesnt help reply here againTomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
August 24, 2007 at 7:12 pm #228085It looks like something within the coding – because there is no reason the Product flypage should be displaying at the bottom of your homepage … unless you’ve accidentally configured your module positions incorrectly.
August 24, 2007 at 8:07 pm #228087<em>@Menalto 25744 wrote:</em><blockquote>Do you use the ja-news module on frontpage?
If that doesnt help reply here again</blockquote>Yes I am using the ja-news module and it is set to show on Home page only.
August 24, 2007 at 8:18 pm #228088<em>@tcraw1010 25745 wrote:</em><blockquote>It looks like something within the coding – because there is no reason the Product flypage should be displaying at the bottom of your homepage … unless you’ve accidentally configured your module positions incorrectly.</blockquote>
I had removed a menu option and this seemed to break it, seems to be working now.
August 30, 2007 at 5:18 pm #228429This same problem is happening to me… you said you had removed a menu option? How did you fix it.
When I select a product off of the slider, it appears at the the bottom of the page (below ja-news); I want Ja-news to go away when a product is selected.
Help?
October 29, 2007 at 11:12 pm #231754Will somebody PLEASE tell me how to resolve this issue? It is excrutiatingly frustrating.
redlight_traitor Friendredlight_traitor
- October 2006
- 8 times in 1 posts
January 2, 2008 at 12:15 pm #235549April 10, 2008 at 7:14 pm #245090bow chica wowwow!
it works for larix!
This topic contains 9 replies, has 7 voices, and was last updated by buglerroller 16 years, 9 months ago.
