  • canadatom Friend
    #129123
    Hi Everyone, I want to make a some product showcase website(No Checkout or Payment System required) something like this http://www.elaistcabinets.com/en/products.php
    I couldn’t find a good product showcase component and modules for this. Would someone give me a suggestion about this? If you have any product showcase site, would you please link it here? Thank you!
    Menalto Friend
    #251346
    From a quick view on that site i think i would do a research for a gallery component, it just depends on how you set it up and i think you can get a result as above.
    notjustcane Friend
    #251608
    <em>@canadatom 56266 wrote:</em><blockquote>Hi Everyone, I want to make a some product showcase website(No Checkout or Payment System required) something like this http://www.elaistcabinets.com/en/products.php
    I couldn’t find a good product showcase component and modules for this. Would someone give me a suggestion about this? If you have any product showcase site, would you please link it here? Thank you!</blockquote>
    hi i am trying to do exactly the same! so far i have tried using rs gallery component (see my site http://www.idigitize.co.uk/adele which is on the home page but this didnt work how i wanted because it just shows product images and i havent been able to get it to display categories. i have just installed the virtuemart component – see xenia ll userguide – i have only activated the component and the product category module because thats all i want so far. make sure to configure to not use the cart then it really is just like a catalogue – you can see it working on my product page (i havent populated it with my products these are the sample products which you can put on at set up. hope this helps – if you need more info on my setup pm me regards Adele
This topic contains 3 replies, has 3 voices, and was last updated by  notjustcane 16 years, 6 months ago.
