Adrien GEORGE Friend
Adrien GEORGE
- 2 times in 1 posts
July 10, 2009 at 9:32 pm #142683Hi there,
here is the thing :
1 – I have entered all my products in virtuemart.
2 – I chose in the configuration of the theme the product list style : Product List (no table, div based) and chose to have the add to cart box in the listbut when I go to the list of products of my categories, I have two problems :
1 – Each of my product appear like 20 times
2 – I cannot have the add to cart boxthanks for your help in advance
bennitos Friendbennitos
- May 2008
- 474 times in 407 posts
July 10, 2009 at 10:28 pm #310664Do you have a live url where i can have a look?
Adrien GEORGE FriendAdrien GEORGE
July 11, 2009 at 10:29 am #310685Hi there, you can access the live url :
eric67 Frienderic67
- January 2009
- 6 times in 1 posts
July 12, 2009 at 7:05 am #310751Do you have sh404sef installed ?
If yes, the problem comes that the site cache is enabled.The site cache must not be enabled when using sh404sef in some case.
Eric.1 user says Thank You to eric67 for this useful post
July 12, 2009 at 9:39 am #310758Hi Eric,
you’re the man ! It works ! I have no more the products appearing several times !
(by the way, i did not have shef404, I just had my cache enabled)2 – Do you have any clue about my second issue : I cannot have the add to cart box appeared in the list ?
eric67 Frienderic67
- January 2009
July 12, 2009 at 10:28 am #310761There are several possibilities…
For instance, go to configuration, Site tab, in display choose configuration theme. Is Show the Add-to-cart Button on the product list checked ?
Do you have a link to your site ?
Eric.Adrien GEORGE FriendAdrien GEORGE
July 12, 2009 at 4:27 pm #310787Dear Eric,
yes i have the “show add to cart button” checked.
You can access the site :
http://www.mestresbrasil.com/fr/inde…d=34&Itemid=71eric67 Frienderic67
- January 2009
July 12, 2009 at 5:30 pm #310790En fait quand tu utilises les attributs, le bouton ajouter au panier n’apparait pas car il faut faire un choix préalable… Peut être ton problème vient-il de là ?
Eric.Normally, when using attributes, the add to cart is not displayed before you have chosen an option. This is a normal behaviour…try to delete the attributes and see if the add to cart button appears…
July 12, 2009 at 6:14 pm #310793Tu as raison, c’est ça. C’est logique. Merci encore pour toute ton aide.
AuthorPostsViewing 9 posts - 1 through 9 (of 9 total)This topic contains 9 replies, has 3 voices, and was last updated by Adrien GEORGE 15 years, 5 months ago.
Products appearing 20 times when Product List Style chosen
