  • kiya14 Friend
    #686153
    If I want to make the products grid looks like this site (http://www.loewe.com/cn_en/loewe-men.html#/page/1).
    Does it easy to modify the template and how can I do? Thank you~
    jooservices Friend
    #686198
    Hi there
    You can choose in one of our template which one suite for you
    http://www.joomlart.com/joomla/templates
    It’s not 100% exactly like your but you can base on similar thing and apply your customize.
    You’ll need know about PHP & HTML / CSS to do that.
    But if you don’t know i would suggest you hire 3rd developer for this.
    Thank you,
    Viet Vu
    jooservices Friend
    #748995
    Hi there
    Thank you,
    Viet Vu
This topic contains 3 replies, has 2 voices, and was last updated by  jooservices 9 years, 2 months ago.
