February 25, 2016 at 9:21 pm #890549
I’m using the default homepage and i trying to create the Tabs module like the demo with a Virtuemart module in each Tab. But now my 4 products appear vertical instead of in a row. I followed the instructions but it stays vertical.
February 26, 2016 at 12:35 am #890569Hi
Kindly provide the screenshot of the problem and Edit your first post and submit the site super user details for JA Mods/ Staff . So i can check it on your site .February 26, 2016 at 8:18 am #890755Hi, i uploaded a screenshot and submited the user details. tnx!
February 26, 2016 at 8:29 am #890759Hi
Add this code in custom.css file
Path : /templates/ja_cagox/css/custom.css
If there is no file , kindly create it and add the code ..vmgroup ul.vmproduct li { float: left; }
Save file and check .
February 26, 2016 at 8:39 am #890765Yes! It works! 🙂 Thanks for the quick support!
AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 4 replies, has 2 voices, and was last updated by nomar 8 years, 10 months ago.
Products in Tabs module not in a row
