August 18, 2007 at 3:41 am #122137
Products not showing no matter which category is chosen, only see non defined at the top
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
August 18, 2007 at 6:51 am #227358Can you please provide and url to your site?
August 18, 2007 at 7:50 pm #227391bluecafe Friendbluecafe
- October 2006
- 2 times in 1 posts
August 18, 2007 at 10:31 pm #227398What did you state in the parameters? Maybe the category settings are wrong?
August 19, 2007 at 5:03 am #227433Tried many different category’s, always same result
- October 2006
August 19, 2007 at 6:53 am #227446Mine is working just by leaving the category setting at zero. Have you tried this?
Michael Casha FriendMichael Casha
- 119 times in 1 posts
August 19, 2007 at 8:02 am #227455Looks like you’ve done the category/section id’s incorrectly.
August 19, 2007 at 9:41 am #227474i have the same problem.
The category-settings are at «Zero»
August 19, 2007 at 4:04 pm #227510As I mentioned I have tried several categories and 0 still not working.
August 20, 2007 at 2:24 am #227539I pay a membership to get support, and support is very slow, I might as well get the templates on warez boards
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
August 20, 2007 at 3:25 am #227544<em>@TechOnCall 25065 wrote:</em><blockquote>I pay a membership to get support, and support is very slow, I might as well get the templates on warez boards</blockquote>
Wow . . . A whopping two days – what a long time to wait.
Most of the time, members/users try to help other members/users . . . and sometimes, we just don’t know the solution within 48 hours.
My suggestion to you would be to try PM’ing or emailing the Admins and see if you can get some assistance that way.lehoai Friendlehoai
- January 2007
- 7 times in 7 posts
August 20, 2007 at 8:17 am #227584Hi TechOnCall,
Tell me how are you config you module’s params now? List all of them here please.
And note tell me how many product and you should try with a categories has least product.lehoai Friendlehoai
- January 2007
August 20, 2007 at 10:19 am #227607I think the mootools library used in slide module is conflict with one in VM LiveSearch module. The VM LiveSearch module uses an old version of mootools library. Please update module VM LiveSearch module or you must choose to use one of them.
August 20, 2007 at 1:16 pm #227609Disabling the search feature has solved the problem.
Thank You
August 21, 2007 at 6:57 pm #227721I have still the same problem.
I have disabled the search fuctions and the categories are at zero.
Here ist the Link http://www.rumotec.ch/testweb/verein/
This topic contains 19 replies, has 7 voices, and was last updated by sjenny 17 years, 2 months ago.
