It is the virtuemart search module that needs to be disabled not the ‘normal’ search. Your virtuemart search module is published (see left column on your site).
ok i have now disabled the VM Search Modul, but the pruducts are still not showing.
:confused:
Hi sjenny,
did you set the use zip javascript file is true. You should set its is NO ( false) in module manage. Try again and tell me result.
Thank for reading and goodluck
This topic contains 19 replies, has 7 voices, and was last updated by sjenny 17 years, 2 months ago.
