  • lemick28 Friend
    #1011876
    Hi when i click add to cart and go to checkout screen no products are added
    tried multiple virtuemart settings and still no change whatsoever
    Please advise
    You can try to switch default template to a standard template of Joomla like Beez/Protostar and check again. This way will help to narrow down the scope of issue. If it works, there is something with template.
    In case, the issue still persists, the problem comes from VM.
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 7 years, 9 months ago.
