  • oldsteel68 Friend
    #127488
    I would like to have 3 columns through-out my site.. I think.. But to have 3 columns I will need to change my category view to 1 product per row because some of my item names are too long and some characters get dropped to a second line..
    What do you guys suggest?
    http://tinyurl.com/6kdhog
    #245257
    Hi oldsteel68 !
    You can change number column for product category in VirtueMart admin area. You do by following steps :
    – Login to admintrator.
    – Go to VirtueMart Component.
    – Select Category Manager then select category
    – Change Show x products per row field.
    View attachment image for detail
    oldsteel68 Friend
    #245324
    i know how to set it, i guess i was more or less asking or opinions.
    2 product per row with no modules in right, or 1 product per row with right modules..
    Cant decide
This topic contains 3 replies, has 2 voices, and was last updated by  oldsteel68 16 years, 8 months ago.
