  • dataweby Friend
    #205297
    I’ve noticed that the custom fields for product are in a layout position of “addtocart”.
    Are there any other possible layout positions for fields?
    Adam M Moderator
    #565926
    Hi @dataweby,
    I am bit confused about your request. Could you please clarify a little bit or provide a illustrated screenshot and I would be able to assist you better.
    dataweby Friend
    #567479
    The custom fields you add for a product in VM can be added in one position only, which is called “addtocart” on the layout.
    The position places the fields on the right of the product images. I was wonderin if there’s a way to place those fields in a different position – for example, to the left of the image instead of the right (or any other pre-set if it was possible).
    Adam M Moderator
    #567602
    Hi @dataweby,
    Actually there’s specific CSS / JS style for the Cart, if you move it to another position, you will have to adjust both CSS / JS code (styling, slide in / out, etc …).
    Adam M Moderator
    #732712
    Hi @dataweby,
This topic contains 5 replies, has 2 voices, and was last updated by  Adam M 9 years, 8 months ago.
