  • maxjaramillo Friend
    #121761
    Sirs:
    When I log into the Public Frontend Editor, I don’t see the drop-down menu for selecting the section. I only see the category and since I can’t select the section, the category is left blank.
    The problem is both for firefox and IE. I have reviewed the global config, and everything seems ok. I read somewhere in the joomla.org forums that there a FRONTEND problem when the joomla site is created in a subfolder which is my case.
    Any help on how to resolve the problem would be much appreciated.
    Thanks.
    ErikThorsen Friend
    #226065
    Not easy to do without a live url or some more info I think…
    maxjaramillo Friend
    #226134
    Please see http://www.latinpressinc.com/acr
    User: test
    Password: 1234
    You will see that there is no Section to select, and consequently, you can’t select a Category, nor save the content. Please advise.
    bigrk Friend
    #226137
    Login details are not correct. I was unable to take a look.
    maxjaramillo Friend
    #226244
    Sir:
    LOGIN indeed correct.
    Site: http://www.latinpressinc.com/acr
    User: test
    Password: 1234
    User Menu: See bottom right hand column under the Adsense Advertisement [User 5].
    Click on User menu to SUBMIT NEWS, and you will see the problem, namely, that there is no Section to select, and consequently, you can’t select a Category, nor save the content.
    Please advise.
    maxjaramillo Friend
    #226486
    I again ask any help from the forum regarding the above problem.
    Section Drop-Down Menu is not showing in the Front-End for the editor?
    Please see attached image of problem.
    Thanks to any helpful answer.
    1. SampleFrontEnd_iii
This topic contains 6 replies, has 3 voices, and was last updated by  maxjaramillo 17 years, 5 months ago.
