  • lockdown Friend
    #1037837
    I have installed Purity III on a site I’m going to migrate into Joomla 3 (now 3.7.2). Before I convert the older CSS site, I want to get all the kinks out of the new Purity III install.
    1) The main problem I’ve noticed is that the Slideshow position is not visible on mobile devices. I’ve made sure it’s set to "visible" on the template’s layout tab, and the template is set to ‘responsive’ on the ‘general’ tab.
    2) The next issue I have not been able to overcome is white boarders/margins under the Slideshow position on the PC version of the website. Currently, there is a small bottom margin/boarder.
    3) The (hopefully) last thing I’d like to figure out is how to make the footer position get a 100% screen width. I think it’s set to that now, but from within a container.
    Any help is appreciated… the main issue is having the Showcase position visible in the responsive view.
    Hello
    Regarding slideshow not showing on mobile devices , you can have a look HERE for solution.
    Regarding your other questions , you can open a topic for each specific problem you are encountering, in each topic add your website url a screenshot showing problem and a temp super user account to allow us to look at it.
    Each information added will be not public but only visible to moderators and admins.
    Best regards.
    lockdown Friend
    #1037869
    Additionally, I had modified the corporate.css file first few lines as follows:
    .corporate .slideshow {
     background: #f7f7f7;
      border-bottom: 1px solid #eeeeee;
      padding: **0px** 0;
    lockdown Friend
    #1037870
    Thanks! That solution solved problems 1 & 2!
This topic contains 3 replies, has 2 voices, and was last updated by  lockdown 7 years, 6 months ago.
