arthurjohnston Friend
arthurjohnston
- November 2010
- 27 times in 2 posts
July 2, 2014 at 2:27 am #199355Saguaros ModeratorSaguaros
July 2, 2014 at 2:58 am #540886It looks like there is something wrong with the LESS file. You should check what you have just done and try to revert it.
arthurjohnston Friendarthurjohnston
- November 2010
July 3, 2014 at 6:40 am #541031The LESS compiler requires at least 128MB memory on your server. Please check the memory_limit if your server can meet the requirement. It’s best if you contact your hosting/server to check this for you as some servers limit this value.
- November 2010
July 4, 2014 at 4:28 am #541150This issue often due to 2 common reasons:
– Incorrect LESS code when customizing
– Lack of memory limitMay I know which is value of memory limit of your site in your server?
- November 2010
July 6, 2014 at 12:00 am #541259<em>@Saguaros 435171 wrote:</em><blockquote>This issue often due to 2 common reasons:
– Lack of memory limitMay I know which is value of memory limit of your site in your server?</blockquote>
Memory limit 512 megabytes.
I was browsing the new messages, and someone mentioned their T3 blank template had a “site/local” folder, where the “Theme Magic”, changes were being saved, and creating memory errors.
I viewed my templates folder layout and discovered a “…/template/local” folder that should not exist. I installed my template via the Joomla Extension Manager.
July 7, 2014 at 3:19 am #541326Seem you’ve updated the new version of T3 framework, within this version, the template will have a new folder called local, it helps to keep your customization/config in template stay when you update template.
If you’ve not customized this template much, please take a backup of your site and update template to newer version and compile less to css again.
- November 2010
July 8, 2014 at 4:00 am #541472<em>@Saguaros 435421 wrote:</em><blockquote>Seem you’ve updated the new version of T3 framework, within this version, the template will have a new folder called local, it helps to keep your customization/config in template stay when you update template.
If you’ve not customized this template much, please take a backup of your site and update template to newer version and compile less to css again.</blockquote>
I have not customized the template or T3. I upgraded to v1.1.0 of the template, and the compile error occurs.
I LOCATED THE PROBLEM!!
I updated to T3 2.3.0, using the template screen. The T3 Framework and the T3 Framework Package were different versions!
I deleted the T3 Framework and Package, then reinstalled and LESS compiles without issue.
Thank you for all of your help.
1 user says Thank You to arthurjohnston for this useful post
July 8, 2014 at 8:13 am #541505Glad to be of assistance 🙂
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 2 voices, and was last updated by Saguaros 10 years, 6 months ago.
Purity III v1.0.0 and T3 v2.3.0 LESS will not compile
