July 21, 2011 at 11:38 am #166559
Hi everyone
After successful testing quickinstall of JA_Travel on my home-host, i have installed same quickinstall on my host (there are more than 100 joomla sites hosted) and it does not work.
The problem seems to be the same as wrote on http://www.joomlart.com/forums/topic/it-wont-install-for-me/, but the TS does not give the solution.
I have checked all plugin/module/template/Ja_manager settings twice and checked joomla system folder permissions – everything looks perfectly fine.
I have also restored myqsldump from home-host to productive – it works the same – blank page.
I cant provide link to admin panel or frontend, but i can provide all information that you will need.
Thanx.
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
July 21, 2011 at 12:00 pm #402287So you are getting a blank page on the front end but can see the back end OK?
Please first try disabling the JA Twitter plugin and see if that helps.
July 21, 2011 at 1:55 pm #402325Yes i can see backend and loading pretty fast, but the frontend is loading to much time, then go to blank.
I have disabled all modules.i’ve turned off all the plugins one by one, but nothing happened. After disabling JA T3 Framework i’ve got massage massage asking me to enable it.
Does the problem starts from T3 framework?
- February 2014
July 21, 2011 at 2:00 pm #402328Please PM me a super admin logon so I can take a look for you. Please include a link to this thread in your PM and a link to your admin panel.
- February 2014
July 21, 2011 at 2:20 pm #402337Oh, thank you very much!
- February 2014
July 21, 2011 at 2:22 pm #402338It is probably a memory limit on your server causing the problem or it could just be that it is unable to create the t3 cache folders. Check with your host to see if their logs show up anything with this regard if you continue to have problems.
This topic contains 8 replies, has 2 voices, and was last updated by borej 13 years, 5 months ago.
