  • a_westcott Friend
    #125695
    I have uploaded quickstart 1.5 to my public_html folder in my ftp, after which I went to my site domain and saw the installation pages. I filled out all that was asked of me, including the sql server database details and then reached the last page, it asked me to:
    “PLEASE REMEMBER TO COMPLETELY
    REMOVE THE INSTALLATION DIRECTORY
    You will not be able to proceed beyond this point until the installation directory is removed. This is a security feature of Joomla!”
    I went to the ftp amd I removed the installation directory and then clicked admin, the page does not seem to exist. I checked my domain again and the installation pages have disappeared and now the following message appears:
    “No configuration file found and no installation code available. Exiting…”
    Yes I see the configuration file in the ftp and the installation code is not there I guess because I removed the installation directory as requested.
    How can this issue be fixed?
    bigrk Friend
    #239126
    Did you try to reinstall again?
    a_westcott Friend
    #239128
    Yes, several times now, but to no avail.
    mj1256 Friend
    #239137
    did you completely remove all of the files from the server for the reinstall?
    did you check your config file to make sure the paths were created
    a_westcott Friend
    #239152
    Yes, it was a 100% fresh install, what is it I have to look for in the configuration file?
    Sorry, I am a newbie to all this!
This topic contains 5 replies, has 3 voices, and was last updated by  a_westcott 16 years, 10 months ago.
