  • kempis20 Friend
    #180640
    Sir,ma quickstart has a problem
    created a folder,extracted quickstart file into it
    wen i go to “localhost” it redirects the page to locahost.com and it doesn’t work
    wat do i do??im actually using mendozite template
    thnx
    Luna Garden Moderator
    #466954
    Hi Kempis,
    I have downloaded and installed the quickstart of JA Mendozite, it works fine.
    Could you re-download the Quickstart and install it again to see what if the problem still remains.
    If yes, then please tell me about your PHP version, and what program you using: XAMP or WAMP.
This topic contains 2 replies, has 2 voices, and was last updated by  Luna Garden 12 years, 4 months ago.
