kansen Friend
kansen
- September 2008
- 12 times in 1 posts
June 7, 2012 at 4:28 am #177890just installed the quickstart of ja wall and the display is not good.
the menu is vertical and the pictures.. not good looking display.. as you can see in the screenshot
any solution?
thanks
kansen Friendkansen
- September 2008
June 7, 2012 at 4:43 am #456396its a problem with Internet explorer 9, chrome works all ok… with internet explorer i see the joomlart.com ja wall demo without problem :S
what could be the cause?
Wall Crasher DeveloperWall Crasher
- December 2011
- 361 times in 300 posts
June 8, 2012 at 3:18 am #456593Hi kansen,
It would be easier for me if you can provide your link.
I install the quickstart on my localhost and does not see issue as yours.
Can you please tell me did you make any change to the template?
And please install the quickstart package on your localhost and take a look.I am waiting for your information.
kansen Friendkansen
- September 2008
June 8, 2012 at 6:48 pm #456678hello Wall
i just installed the quickstart and had that error. (only on ie9, chrome was ok)
i tried to install a joomla from 0 and then install the component, plugins and template. it works fine in this way.thanks for your reply.
cheers.
- December 2011
June 11, 2012 at 2:11 am #456860😉 You are welcome.
June 16, 2012 at 9:38 am #457651Hi Wall,
Could you please take a look at this post: http://www.joomlart.com/forums/topic/ja-teline-iii-v2-ie-9-problem/
Thanks in advance.
- December 2011
June 18, 2012 at 11:02 am #457834Hi kurdse,
I have answered your question at http://www.joomlart.com/forums/topic/ja-teline-iii-v2-ie-9-problem/
Sorry, I can not solve your problem right away.Regards
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 3 voices, and was last updated by Wall Crasher 12 years, 6 months ago.
Quickstart has display problem
