Viewing 1 post (of 1 total)
  • jimcapraro Friend
    #153243
    Trying to install Quickstart version of JANorite (by the way very nice template) but when I go to install sample data I keep getting the error:
    Error: the XML response that was returned from the server is invalid
    is there a Fix
    >>Solved<< I installed it without a writable configuration.php file and then just create the config file at the end of installation.
This topic contains 1 reply, has 1 voice, and was last updated by  jimcapraro 14 years, 4 months ago.
