James Weston Friend
James Weston
- 16 times in 1 posts
March 4, 2012 at 7:32 pm #174605Ok I followed the quickstart installation tutorial that has worked for me previously.
When everything was done and i went to http://www.mybaliconcierge.com it was already done with the message remove installation folder. I renamed the installation file and then clicked on site and I get a Joomla Open source content site.
Any ideas.
If i change the name back to installation then i get the page back that looks like this http://www.mybaliconcierge.com/installation/index.php
Jim
tfosnom Friendtfosnom
- October 2010
- 200 times in 94 posts
March 5, 2012 at 4:47 am #441842Hi Jim
If you get a joomla open site it’s possible you didn’t install the sample data?
Best just to reinstall, if you have the instal folder intact, just delete the configuration.php file and then you should be able to reinstall from the browser.
Blessings ShaneJames Weston FriendJames Weston
March 5, 2012 at 4:53 am #441843Hi Shane am starting to do the reinstall now. In the quickstart folder which folder is the sample data you refer to located in?
Jim
<em>@tfosnom 305105 wrote:</em><blockquote>Hi Jim
Blessings Shane</blockquote>TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
March 5, 2012 at 5:38 am #441845<em>@origomedia 305106 wrote:</em><blockquote>Hi Shane am starting to do the reinstall now. In the quickstart folder which folder is the sample data you refer to located in?
Jim</blockquote>
Which template are you trying to install?Also, the sample data is installed via clicking the “install sample data” button within the second to last step of the quickstart installation process.
March 5, 2012 at 5:46 am #441847Hi Shane,
I am using Tiris. Last night when I installed it and then clicked on the website it went straight to the last stage. It did not give me the option to go through any of teh stages.
Jim
TomC ModeratorTomC
- October 2014
March 5, 2012 at 5:48 am #441848<em>@origomedia 305112 wrote:</em><blockquote>Hi Shane,
Jim</blockquote>
Jim:I thought you mentioned that you were wiping the slate clean and re-installing the template using the quickstart + sample data installation process.
March 6, 2012 at 2:26 am #442089Hi Tom,
I think I have stuffed up big time. Have sent you a PM.
Jim
TomC ModeratorTomC
- October 2014
March 6, 2012 at 2:35 am #442091<em>@origomedia 305404 wrote:</em><blockquote>Hi Tom,
Jim</blockquote>
Jim:
I replied to your PM . . . I will try to help you out.UPDATE:
PHASE ONE COMPLETE . . . Awaiting further instructions as to how you wish to proceed.
(see your PMs)😎
This topic contains 8 replies, has 3 voices, and was last updated by TomC 12 years, 8 months ago.
