  • ianfrase Friend
    #182432
    hi I have uploaded quickstart installation to the website and when I try and install Joomla 2.5 I select my language click next button but nothing happens I get the following script
    installation/index.php#
    it has taken me ages to ftp the files and it is frustrating that I now cannot get the installation going so any help would be greatly appreciated
    ciao
    TomC Moderator
    #473707
    How did you upload the files?
    Did you upload the zip file and then try to unzip form your server, or did you unzip the files to a folder on your desktop and then transfer all of the template files over to your server?
    ianfrase Friend
    #473718
    hi Tom I could not see a facility to unzip the file on the server so I unzipped the files on my computer and uploaded them which seemed to take forever. I have reloaded the installation folder and still get the installation/index.php# response
    so I downloaded joomla 2.5 7 from joomla.org, deleted the installation folder provided with quickstart and loaded the installation folder from joomla.org but still the same response. Do you think it might be a php problem with the server that the website is hosted? Many thanks for your help
    TomC Moderator
    #473818
    Just to make sure … when you performed the quickstart upload/installation process, did you follow the steps as outlined here –> HOW TO CLONE THE DEMO USING QUICKSTART INSTALLATION – A Step-By-Step Guide ???
This topic contains 4 replies, has 2 voices, and was last updated by  TomC 12 years, 1 month ago.
