October 22, 2010 at 3:28 pm #155576
Hello JoomlArt!
I would like to try the template in the new version, but it seems that in the quickstart folder some files are missing!
Could you check the content of this folder?Thank you very much!
Yours sincerely,
Massimoithacaindy Friendithacaindy
- January 2010
- 12 times in 1 posts
October 22, 2010 at 3:46 pm #360122What’s the problem? I used the quickstart (as opposed to just the updated components) installed and appeared correctly.
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
October 22, 2010 at 3:51 pm #360123WHat files do you think are missing. I have just done a quickstart and all appears fine.
October 22, 2010 at 4:48 pm #360130Thank you all for your support!
I have already downloaded 4 times the quickstart folder “Teline III V2”.
The missing files are:
CHANGELOG.php
configuration.php-dist
COPYRIGHT.php
CREDITS.php
htaccess.txt
index.php
INSTALL.php
LICENSE.php
LICENSES.phpand the folders:
cache
includes
libraries
logs
tmp
xmlrpcPhill ModeratorPhill
- February 2014
October 22, 2010 at 5:22 pm #360137Thank you for your rapid support!!
I will later download again the folder!Phill ModeratorPhill
- February 2014
October 22, 2010 at 6:01 pm #360143It seemd we are having a few server issues tonight. Our attempt to re-upload has failed. Unfortunately this will have to wait until the team in Vietnam return to the office tomorrow morning.
Hung Dinh FriendHung Dinh
- 3310 times in 3 posts
October 22, 2010 at 6:24 pm #360145Hi Guys,
The download server is having some issues and the Teline III V2 quickstart is corrupted. We would fix it up in the morning, 7-8 hrs from now.
Its weekend, lets all take a break.
Hung Dinh
This topic contains 8 replies, has 4 voices, and was last updated by Hung Dinh 14 years, 2 months ago.
