suhayb Friend
suhayb
- May 2011
May 24, 2011 at 8:31 pm #164389Below is the error that i get. I am not sure what to do?
I get through the whole installation process without any error except this at the end, and if i skip the install data and complete installation this is what is displayed
Notice: Undefined property: stdClass::$params in C:xampphtdocsT3-
blanktemplatesbeez_20error.php on line 10Fatal error: Call to a member function get() on a non-object in C:xampphtdocsT3-blanktemplatesbeez_20error.php on line 11
——————————————————————————————————————————————–INSTALL SAMPLE DATA ERROR
Error
Some errors occurred while populating the database: Table ‘t3-blank.jos_weblinks’ doesn’t exist SQL=– — Dumping data for table `jos_weblinks` — INSERT INTO `jos_weblinks` (`id`, `catid`, `sid`, `title`, `alias`, `url`, `description`, `date`, `hits`, `state`, `checked_out`, `checked_out_time`, `ordering`, `archived`, `approved`, `access`, `params`, `language`, `created`, `created_by`, `created_by_alias`, `modified`, `modified_by`, `metakey`, `metadesc`, `metadata`, `featured`, `xreference`, `publish_up`, `publish_down`) VALUES (1, 32, 0, ‘Joomla!’, ‘joomla’, ‘http://www.joomla.org’, ‘
Home of Joomla!‘, ‘0000-00-00 00:00:00’, 3, 1, 0, ‘0000-00-00 00:00:00’, 1, 0, 1, 1, ‘{“target”:”0″,”count_clicks”:””}’, ‘en-GB’, ‘2005-02-14 15:19:02’, 0, ”, ‘2010-07-10 23:41:06’, 42, ”, ”, ‘{“robots”:””,”author”:””,”rights”:””}’, 0, ”, ‘0000-00-00 00:00:00’, ‘0000-00-00 00:00:00’), (2, 33, 0, ‘php.net’, ‘php’, ‘http://www.php.net’, ‘
The language that Joomla! is developed in‘, ‘0000-00-00 00:00:00’, 6, 1, 0, ‘0000-00-00 00:00:00’, 1, 0, 1, 1, ‘{“target”:””,”count_clicks”:””}’, ‘en-GB’, ‘2004-07-07 11:33:24’, 0, ”, ‘2010-07-10 23:44:03’, 42, ”, ”, ‘{“robots”:””,”author”:””,”rights”:””}’, 0, ”, ‘0000-00-00 00:00:00’, ‘0000-00-00 00:00:00’), (3, 33, 0, ‘MySQL’, ‘mysql’, ‘http://www.mysql.com’, ‘
The database that Joomla! uses‘, ‘0000-00-00 00:00:00’, 1, 1, 0, ‘0000-00-00 00:00:00’, 2, 0, 1, 1, ‘{“target”:””,”count_clicks”:””}’, ‘en-GB’, ‘2004-07-07 10:18:31’, 0, ”, ‘2010-07-10 23:44:03’, 42, ”, ”, ‘{“robots”:””,”author”:””,”rights”:””}’, 0, ”, ‘0000-00-00 00:00:00’, ‘0000-00-00 00:00:00’), (4, 32, 0, ‘OpenSourceMatters’, ‘opensourcematters’, ‘http://www.opensourcematters.org’, ‘
Home of OSM‘, ‘0000-00-00 00:00:00’, 11, 1, 0, ‘0000-00-00 00:00:00’, 3, 0, 1, 1, ‘{“target”:”0″,”count_clicks”:””}’, ‘en-GB’, ‘2004-07-07 10:18:31’, 0, ”, ‘2010-07-10 23:44:03’, 42, ”, ”, ‘{“robots”:””,”author”:””,”rights”:””}’, 0, ”, ‘0000-00-00 00:00:00’, ‘0000-00-00 00:00:00’), (5, 32, 0, ‘Joomla! – Forums’, ‘joomla-forums’, ‘http://forum.joomla.org’, ‘
Joomla! Forums‘, ‘0000-00-00 00:00:00’, 4, 1, 0, ‘0000-00-00 00:00:00’, 2, 0, 1, 1, ‘{“target”:”0″,”count_clicks”:””}’, ‘en-GB’, ‘2005-02-14 15:19:02’, 0, ”, ‘2010-07-10 23:41:15’, 42, ”, ”, ‘{“robots”:””,”author”:””,”rights”:””}’, 0, ”, ‘0000-00-00 00:00:00’, ‘0000-00-00 00:00:00’), (6, 33, 0, ‘Ohloh Tracking of Joomla!’, ‘ohloh-tracking-of-joomla’, ‘http://www.ohloh.net/projects/20’, ‘
Objective reports from Ohloh about Joomla”s development activity. Joomla! has some star developers with serious kudos.‘, ‘0000-00-00 00:00:00’, 1, 1, 0, ‘0000-00-00 00:00:00’, 3, 0, 1, 1, ‘{“target”:”0″,”count_clicks”:””}’, ‘en-GB’, ‘2007-07-19 09:28:31’, 0, ”, ‘2010-07-10 23:44:03’, 42, ”, ”, ‘{“robots”:””,”author”:””,”rights”:””}’, 0, ”, ‘0000-00-00 00:00:00’, ‘0000-00-00 00:00:00’), (7, 31, 0, ‘Baw Baw National Park’, ‘baw-baw-national-park’, ‘http://www.parkweb.vic.gov.au/1park_display.cfm?park=44’, ‘
Park of the Austalian Alps National Parks system, Baw Baw features sub alpine vegetation, beautiful views, and opportunities for hiking, skiing and other outdoor activities.‘, ‘0000-00-00 00:00:00’, 0, 1, 0, ‘0000-00-00 00:00:00’, 1, 0, 1, 1, ‘{“target”:”0″,”count_clicks”:””}’, ‘en-GB’, ‘2010-07-10 23:44:03’, 0, ”, ‘2010-07-10 23:44:03’, 42, ”, ”, ‘{“robots”:””,”author”:””,”rights”:””}’, 0, ”, ‘0000-00-00 00:00:00’, ‘0000-00-00 00:00:00’), (8, 31, 0, ‘Kakadu’, ‘kakadu’, ‘http://www.environment.gov.au/parks/kakadu/index.html’, ‘
Kakadu is known for both its cultural heritage and its natural features. It is one of a small number of places listed as World Heritage Places for both reasons. Extensive rock art is found there.‘, ‘0000-00-00 00:00:00’, 0, 1, 0, ‘0000-00-00 00:00:00’, 2, 0, 1, 1, ‘{“target”:”0″,”count_clicks”:””}’, ‘en-GB’, ‘2010-07-10 23:44:03’, 0, ”, ‘2010-07-10 23:44:03’, 42, ”, ”, ‘{“robots”:””,”author”:””,”rights”:””}’, 0, ”, ‘0000-00-00 00:00:00’, ‘0000-00-00 00:00:00’), (9, 31, 0, ‘Pulu Keeling’, ‘pulu-keeling’, ‘http://www.environment.gov.au/parks/cocos/index.html’, ‘
Located on an atoll 2000 kilometers north of Perth, Pulu Keeling is Australia”s smallest national park.‘, ‘0000-00-00 00:00:00’, 0, 1, 0, ‘0000-00-00 00:00:00’, 3, 0, 1, 1, ‘{“target”:”0″,”count_clicks”:””}’, ‘en-GB’, ‘0000-00-00 00:00:00’, 0, ”, ‘2010-07-10 23:44:03’, 42, ”, ”, ‘{“robots”:””,”author”:””,”rights”:””}’, 0, ”, ‘2010-07-10 23:44:03’, ‘0000-00-00 00:00:00’);
pallavi_t Friend
pallavi_t
- May 2011
- 6 times in 7 posts
suhayb Friend
suhayb
- May 2011
May 30, 2011 at 2:47 pm #393647Thanks for your reply,
I am using XAMPP at the moment
I created the database using: localhost/myphpadmin —- See picture attached (phpmyadmin1)
Then I tried to install Joomla T3 quickstart —- The database grew —- See picture attached (phpmyadmin2)
but….
It still gives me the same error. It seems that the quickstart app is not producing a table in the database called jos_weblinks, so i tried to create the table myself —- See picture attached (phpmyadmin3)
You posted on the same problem in a different thread, ( I posted this problem more than once, due to the lack of response) You said I quote
____________________________________________________________________________________________________
“Hi,
Have you installed MySQL? if yes
Please check if your mysql connections are set right in this file configuration.php (located in core > user > configuration.php )
Refresh the html page
____________________________________________________________________________________________________How do i access configuration.php – using xampp.
And what should it say??
ThanksI have no idea what to do i am seriously stuck
Phill Moderator
Phill
- February 2014
- 2206 times in 1818 posts
May 30, 2011 at 8:01 pm #393691It is going to be very hard for us to solve it as we do nopt have access to your local install. Plus I use Wamp instead of xampp.
Have you managed to get any other Joomla install to work? If you are using the latest version of xampp it may be the Joomla installer does not handle the latest release of mysql yet.
If this is the only site you have on your xampp install you could try Wamp – http://www.wampserver.com/en/
suhayb Friend
suhayb
- May 2011
May 30, 2011 at 10:34 pm #393715Hey Phil,
Yes, I installed Joomla 1.6.3 the latest release using the same version of Xampp, and it worked just fine.
I will try using Wamp and will let you know.
Thanks Alot for your response. Much Appreciated
1 user says Thank You to suhayb for this useful post
May 31, 2011 at 3:13 pm #393911<em>@suhayb 243669 wrote:</em><blockquote>Hey Phil,
Thanks Alot for your response. Much Appreciated</blockquote>
I, too, am having an issue with installing a quickstart package. I have tried with XAMMP and WAMP and both error when you get to the part about installing the sample data. The quickstart package has version 1.6.0 which is not the most current version. The purpose of the Quickstart package is to have all of the extensions and template already installed and configured.
While I have no problem installing Joomla as a standalone package in either XAMMP or WAMP, I am paying for the convenience of having the quickstart option so that I do not have to sit and configure each and every extension and plugin.
It seems that this installation problem is persistent and I can only assume that it has something to do with the quickstart package. I can manually install joomla and all of the components, extensions, plugins, and the theme individually but I do not have the convenience of “pre-configured” extensions and plugins.
Has anyone who is giving suggestions actually tried installing the TELINE IV quickstart package?
Phill Moderator
Phill
- February 2014
May 31, 2011 at 3:17 pm #393913This thread is about the free package, not Teline IV. What error message are you getting when you install the quickstart?
I have just tried the Teline IV package on my WAMP install and it installed fine.
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 5 voices, and was last updated by
bibliox 12 years, 9 months ago.
Quickstart Installation problem with Installing Sample Data
