Viewing 15 posts - 1 through 15 (of 17 total)
  • iyaburo Friend
    #137028
    I have just used the Quickstart package to install a fresh Joomla-1.5.8 site and this is the error I get immediately after installation.
    <blockquote>PHP Warning: plgContentJA_highslide::require_once(plugins/content/highslide/parser.php) [function.plgContentJA-highslide-require-once]: failed to open stream: No such file or directory in <Joomla-install-path>pluginscontentja_highslide.php on line 67 PHP Fatal error: plgContentJA_highslide::require_once() [function.require]: Failed opening required ‘plugins/content/highslide/parser.php’ (include_path='<Php-Install-Path>PhPincludes’) in <Joomla-Install-Path>pluginscontentja_highslide.php on line 67
    </blockquote>
    The files and folders are all in place. Installation completed successfully and I have removed the “Installation” folder after install. Please help.
    I have other Joomla-based sites on this server, so I know that it is not a server or php problem.
    SP Media Friend
    #286372
    Without being able to see it, best thing I can say is check that the directory permissions are set to at least 755.
    SP Media Friend
    #286392
    Just noticed you’re using 1.5.8 too, the latest JaZinc download should come with Joomla v1.5.9.
    iyaburo Friend
    #286422
    Then it must be 1.5.9
    iyaburo Friend
    #286423
    Hello, SP. Thanks for your response.
    What do you expect to be able to “see”, and how do I make you see it? The only thing that could be seen on this new install is the error message I posted above.
    Permission is correct, because I can use other templates successfully.
    bennitos Friend
    #286424
    check if plugins/content/highslide/ actually exist on your webserver, as the error msg says its missing.
    SP Media Friend
    #286428
    Are you running JaZinc on your local computer or an online web server?
    If it’s a template issue, I’ll try and download the JaZinc Quick Start package when I get home, to see if it’s an error with the package itself.
    As for what I can see, the FTP structure, and admin side.
    Try checking your directory permissions via admin cp -> help -> system info -> directory permissions
    It’s unlikely that will be the cause, but it’s a possibility. Check that HighSlide is installed, working and active too.
    iyaburo Friend
    #286432
    Thanks, sp.
    This is on a server. And, no, I cannot get into the admin CP. Same error.
    iyaburo Friend
    #286433
    All the folders and files are there.
    SP Media Friend
    #286434
    Well if I get the same error when I install later tonight, the JA guys may have made an error of some sort.
    I’ll keep you posted.
    iyaburo Friend
    #286436
    Thanks, SP. I just did another test install with the Zeolite template and everything smoothly. I added the Zinc template, and no problem So, yeah, it’s something with the Zinc QuickStart install.
    UPDATE: I say it is a JA_Zinc QStart problem because I just used the quickstart again to install Zinc OVER my new test install. Install went fine, able to get into the admin panel, but when I tried to get to the frontend, the same error comes up. Even switching templates back to Zeolite now brings up the same error.
    SP Media Friend
    #286442
    Post up the issue in the Bugs forum and mark it for mods/admin attention.
    I’ll verify nonetheless later on.
    iyaburo Friend
    #286443
    SOLVED: I went into the JA_Highslide.php and changed line 67 to look for the parser.php file in the correct location like this:
    <blockquote>require_once(‘Drive-Letter:My-Common-Web-Folderthe-folder-for-THIS-instance-of Joomlapluginscontenthighslideparser.php’);</blockquote>
    So, apparently, the require_once directive wasn’t properly locating the root path to the website location.
    SP Media Friend
    #286444
    It’s quite strange you’d need to provide an absolute path rather than relative.
    Good spy skills either way!
    iyaburo Friend
    #286445
    SP,
    my experience with JA admins is that they are not very responsive, so I have come to rely on forum users like you for assistance. I still have a PM that I sent to one of the admins (AFTER I had posted the question in the public forum) that has been completely ignored for over a week or so, even though I still can’t find answers to the questions I asked in that PM.
    I appreciate your assistance, SP.
This topic contains 17 replies, has 3 voices, and was last updated by  iyaburo 15 years, 11 months ago.
