January 7, 2014 at 4:13 am #193533
Hello there,
It seems that, there is an issue with Quickstart J32When I install via quick start without sample data, the site works (ofcourse with no sample data) and when I tried to install along with sample data, Installation shows as successful however frontend shows blank.
Backend works fine and if I login as admin and change template to “protostar” front end works
any idea?
MoonSailor FriendMoonSailor
- November 2011
- 248 times in 223 posts
January 8, 2014 at 4:07 am #517724<blockquote>When I install via quick start without sample data, the site works (ofcourse with no sample data)</blockquote>
When you choice “Install Sample Data” as “None”, it only installs sample data of Joomla default – not modules configuration – thus your frontend just shows blank. In the case, you need config all modules as per our userguide at; http://www.joomlart.com/documentation/joomla-templates/ja-beranis
Hope that helps.
January 12, 2014 at 4:48 am #518139Thanks for the reply,
<blockquote> when I tried to install along with sample data, Installation shows as successful however frontend shows blank.</blockquote>
Isn’t installing “Quickstart” along with Sample Data mimics the demo site? ’cause that is what I am trying to achieve.
- November 2011
January 13, 2014 at 2:26 am #518165<blockquote>
</blockquote>As mentioned in my previous post, if you install “Quickstart” with “Install Sample Data” as “None”, you need extra steps: re-confict modules, plugin and created menu as instructed in user guide. In normal installation with “Install Sample Data” selected, such manual configuration is not needed, instead pre-defined configuration is auto loaded for you.
January 14, 2014 at 2:46 pm #518432I did install with “Install Sample Data” selected, and that’s where I see issue as blank page.
The file I am using is :
file: jatc_beranis_j32.zip
hash: a0698afc6141f5dffb2703fdbc7ef54e-MM
- November 2011
January 16, 2014 at 3:29 am #518623Please PM me url, ftp credentials of your site, I will have a closer look to detect the root of issue.
January 16, 2014 at 2:56 pm #518720its running on my localhost. I will copy it on a web accessible site and will PM you with details
Thanks-MM
- November 2011
- November 2011
January 20, 2014 at 7:40 am #519031I have checked your site, it shows white page because your hosting don’t have GD Library installed yet.
Please contact hosting provider to enable it.
If your hosting gives you permission or in localhost, following steps would help to install GD Library
1. Find your (proper) php.ini file
2. Find the line: ;extension=php_gd2.dll and remove the semicolon in the front.Then, the correct line should look like:
3. Then restart apache.
Some urls might be helpful for your reference:
– http://php.net/manual/en/image.installation.php
– Windows http://www.dmxzone.com/go/5001/how-do-i-install-gd-in-windows/
– Linux http://www.cyberciti.biz/faq/ubuntu-linux-install-or-add-php-gd-support-to-apache/January 21, 2014 at 4:06 pm #519271yes that did it …. thanks you soooooo much.
GD was disabled-MM
<em>@MoonSailor 406667 wrote:</em><blockquote>@mrmastii,
– Linux http://www.cyberciti.biz/faq/ubuntu-linux-install-or-add-php-gd-support-to-apache/</blockquote>AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 2 voices, and was last updated by mrmastii 10 years, 9 months ago.
Quickstart J32 sample data problem
