  • mitsos92 Friend
    #181166
    I believe there is a problem with the quickstart package as i can’t install sample data. I’ve tried in many configurations locally and in a remote server but without any luck. Please check it out.
    eee0oob Friend
    #469159
    I have tried it on a local host and it worked… haven’t yet tried it on an actual host. 🙂
    we2solutions Friend
    #469210
    I download and install the pack with sample data.its worked for me.plz download again and see..
    thanks
    pentasi Friend
    #469211
    installing on server with php 5.3.3 and it works like a charm
    failed on php 5.2
    mitsos92 Friend
    #470003
    Thanks guys for the responses but i still have no luck with the installation.
    I think there is a way to overcome the problem. I would really appreciate if someone with a working qs installation uploaded a sql backup of his “fresh” database.
    Hi mitsos92,
    Which version of PHP are you using? Please try to upgrade to PHP versoin 5.3.x
    mitsos92 Friend
    #470185
    <em>@Saguaros 342265 wrote:</em><blockquote>Hi mitsos92,
    Which version of PHP are you using? Please try to upgrade to PHP versoin 5.3.x</blockquote>
    It wasn’t php. I am using 5.3.8 and 5.4.7. Anyway, i have installed easily the stable QS without any trouble.
    Great it works now 😉
This topic contains 8 replies, has 5 voices, and was last updated by  Saguaros 12 years, 1 month ago.
