reachthesky Friend
reachthesky
- July 2008
- 19 times in 10 posts
July 16, 2008 at 9:14 pm #130951Hey guys. I’m working on a local offline server for testing purposes and I installed the quickstart package of Xenia II shopping edition for J15. Installation performed flawlessly however I noticed that in the catalog when I;m going to click on product details the code doesnt load properly. instead of showing:
it shows:
http://localhost:85/test1/%7Bproduct_flypage%7D
I’ve check the browse_1.php file. everything seems to be in order. I performed two different installations in two pcs (offline both)
I made sure modrewrite was activated. and still the issue persists. It might be that one of the VM files got altered (at least thats what I[‘ve read) unfortunately i have nothing to compare them with.
I honestly don’t know what else to try and I don’t want to mess it up if the site goes live.:((
Could any of you please point me towards a solution. I searched in the forum but I wasnt lucky to find a solution (most of them didnt work)
reachthesky Friendreachthesky
- July 2008
July 18, 2008 at 1:28 am #260592mm..well I thought I had to set the website online to get some attention.
The website can be seen running live at http://www.mkcommercial.com
could any of the support guys take a look at it and provide some assistance?
- July 2008
July 23, 2008 at 9:59 am #261694Perhaps I expected a little bit more of the paid support, I wish on my next problem (we always have) a response shows up a little bit faster. * please take the comment as feedback rather than flaming
Anyway, I know a lot of pple has the same problem I was experiencing. On the download page of the quickstart package I found this solution:
davidyv
07-08-2008 at 10:47 AM Please fix the componentscom_virtuemartthemesdefaulttemplate sbrowsebrowse_6.php of quickstart:
change the 15 line:
<a class=”prod-details” href=”{product_flypage}” title=”<?php echo $product_name ?>”>[<?php echo $product_details ?>…]</a>to:
<a class=”prod-details” href=”<?php echo $product_flypage ?>” title=”<?php echo $product_name ?>”>[<?php echo $product_details ?>…]</a>so, I guess one of the admins could close this thread as it has been resolved and hopefully update the package to avoid same problem to other users.
Best Regards.
bigrk Friendbigrk
- February 2007
- 45 times in 15 posts
July 24, 2008 at 4:07 am #261895I just found your thread looking for info about VirtueMart. I’m sorry none of the developers took the time to help you out. I will close this thread and mark as SOLVED. 🙂
This topic contains 4 replies, has 2 voices, and was last updated by bigrk 16 years, 5 months ago.
