  • paocuba Friend
    #206581
    I use the template JA Sugite in a site and while I work in the local server customizing, everything was Ok. Today publish the site, but when I enter in the administration area any module showing the configuration tabs. It happens the same with the components and content. Not so with the Global Configuration maintaining their respective tabs. I’m using the superuser account
    Has anyone had this problem before?
    1. error
    Ninja Lead Moderator
    #571678
    In this case, I would like to check that bug directly on online site, you can pm me URL of your site and admin login. I will help you to check it further.
    #736724
This topic contains 3 replies, has 2 voices, and was last updated by  Ninja Lead 9 years, 7 months ago.
