February 6, 2010 at 9:32 pm #148467
username: admin
pasw: *********
http://sev.x25.pl/ftp:
host: sev.x25.pl
login: *******
pw: ******after connecting to start button from main menu the article
slideshow disapeared, big area came into view and headlines module stopped workI don’t understand it
uniquebiz Frienduniquebiz
- February 2010
- 156 times in 119 posts
February 7, 2010 at 9:10 am #331876<em>@jacekt 163863 wrote:</em><blockquote>******Removed logon details – PL *********
slideshow disapeared, big area came into view and headlines module stopped workI don’t understand it</blockquote>
Whoa Please do NOT post details in forum, send via PM/email to moderators or support personnel !
Shannon
1 user says Thank You to uniquebiz for this useful post
February 8, 2010 at 2:40 am #331937hey i had the same problem, once i turned of JA Compress everything worked. I had ja slideshow and news ticker not working at all. JA Compress seems to be the problem. If someone can post how to configure it properly so it can be used that would be great 🙂
Saguaros ModeratorSaguaros
February 8, 2010 at 7:10 am #331973Dear guy!
I found the problem happening on your site, That is from the System – Modalizer plugin, you made a mistalke of configuration, In the Advanced Parameters Group , you set
<blockquote>
include MooTools script Yes
Include JQuery script Yes
</blockquote>With above configurations to allow the plugin loading two libs in same time, so the those libs conficted and some our modules did not work on your site.
I re-confiugred the plugin, the website is work well. please check this for meThanks
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 4 voices, and was last updated by Saguaros 14 years, 8 months ago.
rasite slideshow and headline modules problem
