March 25, 2010 at 11:34 am #149799
Have the latest release JA Rasite. When having the forum Kunena active it disturbs the layout of the user6-10 modules (i.e. white background instead of black).
Any ideas? :((
Saguaros ModeratorSaguaros
March 27, 2010 at 2:41 am #337960Dear fronsky!
can you pls give me the link to your site, i have not any sites same as yours, so that i would like to have a closer look on the issue
thanks
March 28, 2010 at 12:25 pm #338096Sorry, it’s not a live site (yet)
I think the issue has to do just with rasite, because it shows the layout problem also with other components activated and not Kunena.
The problem arises when there is just 1 module active in the user6-user10 area!!.
If two or more modules active the layout is ok
Just one module active: layout is disturbed in module area (see attachment “example one-modules.jpg”)Probably something with stylesheets. I loaded the new version of JA Rasite on March, 24 and before there was not a problem. The only other thing I also changed was implementing a new version of Kunena.
Rgds,
F-
March 28, 2010 at 1:37 pm #338104
Hi.
After a compare of the params.ini and changing “ja_screen” from “auto” back to “fix” the layout is ok.
Looks like this “auto” setting gives the mentioned layout problem…….
March 31, 2010 at 8:24 pm #338659Any ideas??
<em>@fronsky 171804 wrote:</em><blockquote>Hi.
Looks like this “auto” setting gives the mentioned layout problem…….</blockquote>
April 1, 2010 at 10:36 am #338749Dear fronsky!
I am sorry that I have not detected the issue yet. because the site is working well after i made some changes as you mentioned;
I highly recommend you re-download the package and try to upgrade your template, which version do you use ? the newest version is now 1.01.
April 1, 2010 at 8:35 pm #338818As I mentioned this is the same version I use. I downloaded the package on March 24.
To be sure, I’ll download again, reinstall and see what happens. I’ll keep you informed as soon as I’ve done that.
rgds,
F -
Viewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 2 voices, and was last updated by fronsky 14 years, 6 months ago.
