  • vagabras Friend
    #142372
    All articles on the Front Page links and the read more link are producing 501 Error messages. Looking at the URL they have extra characters “amp;” that are causing the problem and I’m not sure how to go about fixing this issue.
    If you remove the extra characters then the link works ok.
    Example:
    Bad Link:
    “http://wichitafsc.net/index.php?option=com_content&view=article&id=111:may-2009-test-results&catid=52:testresults&Itemid=96”
    Good Link:
    We have consulted our Hosting Provider and they state the problem is with the link that is generated which is causing a mod security rule to be violated. They suggested modifying the code to remove the extra characters. However, I’m not sure what to modify to fix this issue.
    Web Site: http://www.wichitafsc.net
    kallan Friend
    #309718
    Are you running anything to make your urls more search engine friendly?
    If you are running Joomla 1.5 you may want to try turning on the basic joomla search engine friendly urls in the configuration.
    Regards,
    daylin Friend
    #313273
    I am not sure if your question has been answered to your needs. Do you still require support for this matter?
    If you still require support please provide a livelink to the website in question if you have not done so already.
    >Your question is probably best for the Joomla.org forum. http://www.joomla.org
    Also, are you using Firefox with the Firebug extension to help solve design problems and source code acquisition? If not, we encourage you to start using Firefox with the firebug extension to minimize the amount of questions you may have. It is free.
    Please click “Thank You” and “Donate” some credits below if I provided you some valuable help. If your problem has been solved find the best answer and click “Mark Best Answer”
    Good luck and Thank you for allowing me to serve you,
    Daylin
    b4de4nd Friend
    #330653
    I have the same problem, my article links dont work either…
    however mine does not include the “amp” mentioned here….
    My site works fine and well on my “nonlive” server http://85.83.18.231/haargalleriet
    But on my host http://www.haargalleriet.dk it doesnt work…
    if you guys can help ill be sure to donate…!
    ilnadcruz Friend
    #336768
    Old Guys Rule Coupon codes are coupons that are only valid online, they are special Old Guys Rule discount codes. Get all Old Guys Rule Coupon codes and Old Guys Rule Discount codes from deals365.us and get Discount Online Shopping. Get the best Old Guys Rule Coupon code from Deals365.us to save your budget while Shopping at Old Guys Rule.
This topic contains 5 replies, has 5 voices, and was last updated by  ilnadcruz 14 years, 9 months ago.
