  • anthonyberot Friend
    #178565
    On my front page the read more lings do not work for all modules (Sl1-1 Sl1-3) the article in SL1-2 works.
    Website http://www.contrastnewspaper.com
    Can you suggest a fix?
    Manos Moderator
    #459061
    Please disable any SEF component you might be using and see if that helps you.
This topic contains 2 replies, has 2 voices, and was last updated by  Manos 12 years, 6 months ago.
