ssinha Friend
ssinha
- July 2014
- 12 times in 1 posts
May 2, 2015 at 1:48 pm #206026Ok, just when we thought we were 99% complete with of our website based on Teline V, I committed the cardinal sin of upgrading the template to the latest version of Teline V. Not thinking that it would wreak havoc on all the customizations of the last 4 months, I soon realized my mistake, or rather stupidity. :-[
So I tried to roll back to the previous version which thankfully seems to have worked for the most of the part, I still have this one problem that I need to resolve.
The Read More in JA Advanced Custom Module is messed up. Please see the two images attached (BEFORE and AFTER). I would like it to be as it used to be before. Help please. Thanks.
Ninja Lead Moderator
Ninja Lead
- November 2014
- 3854 times in 3563 posts
ssinha Friendssinha
- July 2014
May 4, 2015 at 4:43 pm #569383Hi Ninja, thanks for your help. Your solution worked for the JA Advanced Custom Module on the front page. But I just noticed that the problem is more than just the JAACM as it appears in all Category Blog menu as well. The Read More is stretched as shown in the previous picture.
Appreciate your help very much in resolving this issue.
ssinha Friendssinha
- July 2014
May 4, 2015 at 4:43 pm #734472Hi Ninja, thanks for your help. Your solution worked for the JA Advanced Custom Module on the front page. But I just noticed that the problem is more than just the JAACM as it appears in all Category Blog menu as well. The Read More is stretched as shown in the previous picture.
- November 2014
May 5, 2015 at 10:33 am #569492Which area are you referring to on your site? Things at least look to be running smoothly from what I can see.
ssinha Friendssinha
- July 2014
May 5, 2015 at 12:12 pm #569505Ninja, please check your PM. I have explained the problem in it along with the backend login info for you. Thanks.
kmgdesign Friendkmgdesign
- October 2013
- 4 times in 3 posts
May 5, 2015 at 1:21 pm #569523Thank you Ninja!
ssinha Friendssinha
- July 2014
May 5, 2015 at 2:05 pm #569533Ninja, ignore this. I just upgraded to the latest Teline V update and it resolved the problem. Thanks as always.
1 user says Thank You to ssinha for this useful post
ssinha Friendssinha
- July 2014
May 16, 2015 at 12:23 am #570754Ninja, please refer to #3 above. For some unknown reason, the problem is back. I swear I haven’t done anything in the last few days but today the Readmore in blog menu is once again stretched from left to right edge. The frontpage is fine but not the blog menu pages. Last time I had reinstalled the template and that took care of the problem but with all the customizations we have done in the last 3-4 months, I am afraid reinstalling the template would mess up many other things. Need your help. You can still use the last user name/password to log into the backend. I will send you a PM just in case you don’t have the username/password. Thanks for any help.
- November 2014
May 18, 2015 at 3:43 am #570856@ssinha: You can fix the problem with my solution below
Open templates/ja_teline_v/css/custom.css file and add new rule
.items-leading .leading .readmore a, .items-row .item .readmore a {
display: inline-block;
}1 user says Thank You to Ninja Lead for this useful post
- November 2014
May 18, 2015 at 3:43 am #735918@ssinha: You can fix the problem with my solution below
Viewing 12 posts - 1 through 12 (of 12 total)This topic contains 12 replies, has 3 voices, and was last updated by Ninja Lead 9 years, 6 months ago.
