  • Pankaj Sharma Moderator
    #1066218
    Your question is not clear, can you give some more details of issue with a screenshot of issue and URL.
    dohdaiga Friend
    #1066312
    #1066319
    In Joomla if an article or category does not assciated a menu it open on the default homempage or the parent page.
    As in demo the all demo site pages does not have the component section and using only module position
    That’s the reason the content of article not showing.
    Kindly create a menu with type category blog and select 148-church category in this menu.
    So when you open article under this category it opens on the blog menu, not under homepage and article will be visible.
    For demo site, I will ask concern team to add a menu for this category.
    dohdaiga Friend
    #1066334
    are we talking about the "read more" feature here? Isn’t that link created automatically from within the article?
    but the articles are not showing!
    #1066341
    Readmore option is for the menu like category blog, on full article page Joomla display full articles.
    You can check the same with any other Joomla template.
    Try the above suggestion to show the articles.
    dohdaiga Friend
    #1066351
    Please give me step by step instructions. I tried, but it didn’t work. I must be missing something.
    #1066354
    Kindly create a menu with type category blog and select NEWS
    (148-church) the category in this menu and save it.
    Now when you open article under this category it opens on the blog menu, not under homepage and article will be visible.
    dohdaiga Friend
    #1066361
    that’s in there already: https://imagebin.ca/v/3cpsUolRSrWN shot
    are you referring to a menu or menu item?
    • This reply was modified 7 years, 1 month ago by  dohdaiga.
    #1066364
    You have to create a menu menu
    Type: category blog
    select news category in this menu item > saves and check.
    All article under new category will open under the menu you created.
    In your screenshot, you have not created any menu item.
    dohdaiga Friend
    #1066366
    Type: category blog
    There is no such thing in the menu creation options: https://imagebin.ca/v/3cpwwVSALVID
    dohdaiga Friend
    #1066425
    Hi Pankaj,
    Sooo sorry about the back-n-forth you were absolutely right. I created the menu and linked to the category as you said. It is working smoothly
This topic contains 11 replies, has 2 voices, and was last updated by  dohdaiga 7 years, 1 month ago.
The topic ‘read more links not displaying articles’ is closed to new replies.
